Sound acquiring using myRIO's Audio in port
Hello
I'm using an H1C hydrophone as an input device for the myRIO i'm connecting it through a PA-4 hydrophone preamp.
yet the signal i'm getting is still too week and insensitive (amplitude of 0.8 of max 2.5V)  compared to the one i get when connecting the H1C directly to the PC mic in port.
 this is the VI i'm using
PA-4 preamp configurations
(2,323 Views)
Does it work better if you replace the brown Waveform tunnels with Shift Registers?
(2,219 Views)
Thank you for your reply No it doesn't. what confuses me most is that the preamp. has a +50 dB gain
(2,171 Views)
