Sound & Vibration
We are measuring the Machine Condition Noise using Microphone & Accelerometer we are interested in eliminating the external noise caused by the industrial enviroment. What kind of filters can be used to eliminate the external noise. Is there any standard procedure to follow or obtain  the better quality signals measurement.
(2,655 Views)
It really depends on what the frequency spectrum of your noise and of your measurement.  You want to filter out your noise only without accidentally filtering out your signal.  First, you should plot a frequency spectrum to see what you have first.  Then, you can decide do you want a low, band, or high pass filter.  You can do the filtering either through circuit (analog) or within your code (digital, DSP).
Kudos and Accepted as Solution are welcome!
(2,639 Views)
