01-25-2010 09:16 AM
Can we install Sound and Vibration 7 on LabView 2009 ?
I tried to install it but there is no option to select LV2009
01-26-2010 03:12 AM
Any replies please. 🙂
01-27-2010 01:25 AM
01-27-2010 03:51 AM
Unfortunately, there is no way for you to install Sound and Vibration 7 to LabVIEW2009 via the SV7 installer. For LabVIEW2009, Sound and Vibration 2009 is the right version. But if you do want to try SV7, you can try to do this:
1. Install SV7 and select 8.6 supports from the feature tree, you need to have LabVIEW 8.6 in your system for this.
2. When the installation completes, copy all folder and files under \National Instruments\LabVIEW 8.6 into \National Instruments\LabVIEW 2009.
3. Mass compile vi.lib\addons.
4. Launch your LabVIEW and have a try.
01-27-2010 05:08 AM
