Sound and Vibration Assistant: Exporting to wave file?
I have been using Sound and Vibration Assistant for a while now and can not figure out how to export/convert a recorded signal as a listenable wave file. Currently my only options under Add Step/Save Signals are ASCII and UFF58 file types. Let me know, thanks in advance!!
(2,317 Views)
http://forums.ni.com/t5/LabVIEW/acquire-analog-input-sound-for-10-seconds-display-and-save-as/td-p/5... See that thread. There is a VI that does this, assuming your data is a waveform. If its xy data you'll have to build the waveform yourself.
(2,307 Views)
