Sound and Vibration Toolkit LB2013
Dear all
I had worked a few years ago in a projecto to calculate acceleration in position
Here I am again, and after some searchings here in the forum, this matter stills gives fighing...
The principle is simple, double integration and voilá, we have the position/displacement...but seems to no be so simple.
Basicly I have a laser to measure the distance (regularity) to the ground in movement and I need the cut out invalide distance from zz acelerations, by calculate de distance from accelerometer and subtract the distance laser. I will not expect success but at least doing better since few years ago 🙂
In the past I had the Sound and vibration toolkit, but I could not find a version for my licensed LB 2013.
Can someone help find this version?
Best
CPalka
Message 1 of 12
(1,472 Views)
Dear all
What are the version of the Sound and vibration for Labview 2013?
My LB2013 license gives me access to this toolkit?
Best regards
cpalka
Message 2 of 12
(1,330 Views)
LabVIEW Sound and Vibration Toolkit download link
You might need SSP to access the download link. See Download Previous Versions of NI Software
If you want to know what software and version you can access, fill in your serial number into Activation Code Generation page] and check the dropdown menu of Select the product that you want to activate
https://tmesystems.net/
Message 3 of 12
(1,319 Views)
Hi Zyong
I tryed activation code generation, and i received an email with this inf below. This means that I can access to the SV toolkit 2013 version? In donwload page, after selection version 13, the download button is not accessible
Serial Number:
xxxxxxxxx
Product:
Version:
13.0
Activation Code:
xxxxxxxxxxxxxxxxxx
cpalka
Message 4 of 12
(1,289 Views)
Yes
As I have mentioned, you need SSP to download previous version of software. See Download Previous Versions of NI Software
Message 5 of 12
(1,284 Views)
Hi Zyong
The page Download Previous Versions of NI Software only inform the conditions, but where can I get the link for download? I must contact NI Support? As indicated in this page?
Best regards
CPalka
Message 6 of 12
(1,263 Views)
If you have a valid SSP, Register Products to MyNI User Account and you would get access to the download link.
Message 7 of 12
(1,256 Views)
Hi CPalka,
Yes.
Message 8 of 12
(1,241 Views)
Hi GerdW
Strange because I receive an email with an activation code for Sound and vibration toolkit versin 13.
I go to licence manager and when i enter this code, give me the information "this activation codes do not correspond to any products you are activating"
In download previous versions, the download button stills grey
Best regards
CPalka
Message 9 of 12
(1,236 Views)
Hi CPalka,
That's why you should contact NI: to be able to download the LV2013 version of this toolkit!
(NI will/should provide you a download link after you prove your valid license for LV2013+toolkit…)
Message 10 of 12
(1,224 Views)
