Sound and Vibration Toolkit with NI-SCOPE AND NI-FGEN
I would like to use the Sound and Vibration Toolkit with the NI-FGEN and NI-SCOPE,specifically the stepped sine analysis. The stepped sine VI's are compatible with only DAQmx and not NI-SCOPE and NI-FGEN,right?
Any way around this?
(2,572 Views)
Hi there,
Firstly I assume you mean Swept sine and not stepped!?
This is the closest thing I could find:
I had a look for you and there is nothing that works with a swept sine in FGEN or SCOPE natively that we supply.  However I do believe that a lot of the functionality could be programmed in FGEN and SCOPE vi's.
You would however need to make copies of all the Swept Sine VI's and replace all DAQmx calls and property nodes with the appropriate SCOPE/FGEN vi's.
Not a short answer I'm afraid and I can't guarantee that all the functionality is going to be there.
Sorry its not a better answer.
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
(2,547 Views)
