Sound and vibration signal simulator box
When i am giving 0 to 5volt output from sbRIo to the  sound and vibration signal simulator box to control the speed
the fan rotates very slow but when i a potentiometer present on board(manual control) there is  linear relation with the input and output...
Max RPM being 6000
when i give output from the controller previously it was running on 4000 after few days 3000rpm and then 2400 now its very low and almost 1000 RPM
may i know the solution to rectify this...
(4,058 Views)
have you measured the real output voltage?
Simyfren
(4,041 Views)
 output at the output pins of sbRIO's give expected voltage  which i am giving in the program but still the fan is running under very  RPM
(4,023 Views)
If is the fan controlled by output voltage and you have corrected value of voltage, there is no problem in code but problem is with fan.
Simyfren
(4,013 Views)
ya previously with the same code my fan use to run properly but now its giving weird output
(4,008 Views)
