Sound card Sample rate
Is there any way to get sample rates for the sound card output that are not the usual settings ie 44.1KHz, 22.05kHz etc I need to send out sound at 33.33kHz.
(3,231 Views)
     The  sound card do not support all sample rates. Which sample rates your sound card support you will find in the the manual.goto help in the toolbar select find examples and search for sound Open the Sound Input to File.vi file.This will give you a template for recording sound.You have to set the sample rate then open a sound file for write.
Please post a sample VI that you have created.
also,please go through this:-
http://www.zeitnitz.de/Christian/waveio
Thanks as kudos only:)
(3,223 Views)
