Sound cards
There is a problem in Labview that you cannot read and write to the
sound card in the same program. If you do this the input and output
signals become mixed together. ie you cannot isolate the output
independantly from the input. I read somewhere that you need to install
a second sound card. Has anybody ever done this in LabVIEW? Even
installing two working sound cards sounds daunting.
Tom
(4,142 Views)
Hello Tom
Well, Probably you can do what you want with only one card.
Open the "windows mixer", "sound control" or whatever is call in your computer. In "record options" select, lets say, "line input". In "playback options" check "line input" to be "silent". This should avoid your input signal to be heard, and mixed with your generated signal
Bear in mind that there are different sound cards an sometimes, mixers an options are not the same, so try combinations until you can get your goal.
Hpe this helps.
"Qod natura non dat, Salmantica non praestat"
(4,142 Views)
If you have full duplex card you can do it. I performed sound input and output at the same time with single card and it worked fine.
Be careful with windows volume control mixer.
Good luck.
Oleg Chutko.
(4,142 Views)
alipio wrote in message news:<506500000005000000CD2C0100-1042324653000@exchange.ni.com>...
> Hello Tom
> signal
> your goal.
> Hpe this helps.
Thanks but muting the line input then means I have an output but no
input as it cuts off the input altogether.
Tom
(4,142 Views)
In data Tue, 14 Oct 2003 17:07:02 +1300, Tom ha
scritto:
When you say "write to the sound card" you say write only *.wav files or
also real time generated waves? In other words: can I "play" directly a
sine function with a sound card?
Thank you.
Michele Giordano
(4,142 Views)
