Sound for random arraypairs
Hello!
I would like to ask something.
I have 2 arrays with 4-4 roster,where i generated random arraypairs.
In this case : Pali - Hajni // Peti - Heni // Tomi - Robi // Zoli - Teri.
I want to know ,that can i record the arraypairs,if i make a soundfile for every name? I mean , when i make a random list,for example : Peti-Heni,then the program give me back the soundfiles from these names.
Im really looking forward to getting your answer and if you have time for this,i will be very pleasured and say a big thanks to you.
(2,996 Views)
One way to do this would be to use arrays of clusters instead of arrays of strings. The first element in the cluster would be the name, the second element would be the path to, or name of, the sound file.
MC
(2,961 Views)
