Sound pressure frequency measurement
I try to use a USB board(USB-1408FS) connecting a sound meter's AC out port, and do FFT analysis to get the frequency spectrum under Labview.
Can anybody help me to write the Labview block diagram?  Thanks.
(2,779 Views)
AS321:
LabVIEW has a set of Express VIs that allow you to compute the FFT of your input signal. Depending on how you are reading/storing your data (array, single point,...) you may need to masage the data before using that Express VI. Take a look at the attached VI that uses a Simulated Signal as input. I hope this helps.
Rudi N.
(2,753 Views)
