Sound signal acquisition at lower number of samples
Hi
Good day.
I am beginner to LabVIEW software and recently working with LabVIEW 2017 for data acquisition.
I have to acquire respiratory sound signals continuously using a digital stethoscope connected to PC via audio jack. I need to perform multiple recordings in one acquisition, so I added a waveform chart into the vi for continuous acquisition and write to measurement file for saving data of multiple recordings.
I need to acquire sound signals at lower number of samples (such as 100Hz). When I change the number of samples from 10000 to 100, it showing some errors.
How could I acquire the sound signals at lower number of samples? Could anyone guide me on this?
Attached here is the vi responsible for sound acquisition and errors shown.
Thanks.
Priya
(2,212 Views)
You are likely overrunning your read buffer.  You really should separate your acquisition and outputs.  Do this by using a Producer/Consumer.  The idea is to have your acquisition in a single loop and use a queue to send the data to another loop that can then write the sound out and/or write the data to a file.
(2,183 Views)
