Sound wave sampling frequency problem
Hi guys,
I am trying to use a couple of bandpass filters on a few wav files, but I am having problems.
It works for frequencies below 4000, but anything above that I have problems. I assume it is because the total number of samples is 8000 per channel. Is there a way I can increase that to 40000?
Here the vi with the problem.
(2,808 Views)
It's not the number of samples but the sampling frequency.  Here's one way to understand it -- there are three numbers important in digital signals -- the Sampling Frequency (SF), the Number of Samples (N), and the total time (T) of the sample.  They are closely related by the equation N / T = SF (which makes sense, Number of Samples per Time = Samples per Time).  It can also be written SF * T = N.
Now, what is the lowest, and highest, sinusoid that can be represented in the N samples?  The fewest number of sinewaves you can put in is 1.  1 wave in T seconds, 1/T, is the lowest frequency that can be represented.  The fewest points to define a sine wave is 2, one at the peak, one at the trough.  So the highest frequency that you can extract from a waveform sampled at SF is SF/2 (or N/2 divided by T = SF/2).
In your description of the task, you mention N, but don't say anything about SF.  Increasing N can allow you to represent lower frequencies, but doesn't change the maximum frequency.  To do that, you need to increase the sampling frequency.
Bob Schor
(2,783 Views)
