Soundcard in temperature control system?
Vitvip:
That's pretty 'cool' and thanks for taking the time to answer. So you rectify the output of the soundcard, changing to a DC level which is amplified to power the heater. Now I beleive I understand. Wish I could give feedback on sound output, but I have no experience 'hear'. An analog out DAQ card would appear to be a more conventional approach.
Good Luck, your work 'sounds' interesting.
-Pete
Message 11 of 14
(812 Views)
Vitvip,
I guess I don't understand what you mean by "controllable". I can have the computer generate a tone without a break (silence) in the generation of that tone. I cannot, however, vary the amplitude or frequency of that sound. I've attached two VIs, one for LabVIEW 6i and the other for LabVIEW 6.1. They both output continuous sound from your sound card but the frequency cannot be changed once the program is begun unless you stop and restart the task. Let me know if this helps out.
Best Regards,
Chris C
Applications Engineering
Message 12 of 14
(798 Views)
Chris,
thank you for being that explicit, your VI's of course work. Though I insist that you _can_ control frequency and amplitude. Just change it right after the start and wait a little. This delay is huge (for me) and thus in fact you are right that you _cannot_ control the parameters.
And of course by 'controllable' sound output I mean the ability to change the amplitude of the sound anytime without significant lag. Please see my post with the details of the whole setup, it may help to better understand the problem.
Thanks again.
Best wishes,
Vitaly
Message 13 of 14
(792 Views)
Hello All,
The issue here is the way the sound write VI functions (and on a lower level it might be the way Windows functions).  Take a look at Chris's VI and notice that in "highlight execution" mode, you should be able to change the frequency of the wave and notice the results immediately.  Switch back to regular and the response is greatly delayed.  This was a huge clue as to how that VI works!  The VI is buffering the data from the waveform generator.  For instant response from your soundcard you will have to delay the execution of that loop until the time that the soundcard is caught up.  You can either put a delay in the loop (I found that on my machine 40ms was about perfect), or you could use the sound wait VI (in LabVIEW 6.1 it is a VI mixed in with the other sound output VIs).  If you use the sound wait VI, you are guaranteed to have the buffer cleared before the next waveform is played, but you will hear a break in the sound.  If you use the delay method, timing it perfectly might be an issue.  Unfortunately with this older (non-supported) version of LabVIEW, this may be the best we can do.
While this may be the best LabVIEW 6 can do here, you might have some luck calling external code.  You might be able to find some Windows API calls which can output sound, or you might be able to find an ActiveX control witch can do it.
Please let us know if you have any additional questions on this!
Travis M
LabVIEW R&D
Message 14 of 14
(770 Views)
