Source code control
I'm using LV6.0.2 PDS, German edition.
Working on a larger project, I wanted to introduce that SCC tools. But it
seems, that I made some mistakes, when I was installing LV on my NT-machine.
Apparently I didn't install with the Administrator option, so LV reports
errors like SCC configuration not correct, Administrator has not configured
SCC... The manuals tell me, that there should be Administrator menu to
config SCC, but my installatiuo hasn't.
Can I fix this problem without completely uninstall and reinstall the whole
system?
Thanks for your help
(2,644 Views)
You can install the administrator option any time you want. Please read the following explanation:
Administrator: You will only have this option if you chose to install this feature when you installed LabVIEW. If you want to have administrator options but you do not have them yet, then you can get them by inserting the LabVIEW CD, going to Add/Remove, choosing Professional Tools, and clicking on SCC Administrator. Choose the "will be installed on local hard drive" option. The Administrator sets up where all of the VIs will be located on a network. From the SCC Administrator window, you have the option to select the SCC system that you are using. LabVIEW can be used with other SCC systems like Visual Source Safe. If you choose "built in", then you are using the SCC t
hat comes with the LabVIEW Professional Development System. Choose "configure" to set the Master directory where the files will be stored. This Master directory should reside on a Host machine that is accessible to all engineers (Local machine) over a network. The Master directory houses the Projects that the engineers create.
(2,644 Views)
