Source control client under linux
Is there any possibility of - or outlook to - integrating source control clients under Linux with LabVIEW ? We have a CVS server and several Windows machines logging into it using LabVIEW, but would like to achieve the same with our Linux boxes.
Message Edited by Raistlin on 05-07-2007 04:46 AM
(3,354 Views)
Hi Raistlin,
You could take a look at this post. I think it will help you.
regards,
Julien Roland - District Sales Manager
NI Belgium - Technical Support
Don't forget to rate a good answer
(3,332 Views)
As I already thought, there are different solutions on Windows but the combination CVS - linux - LabVIEW does not seem to be supported right now. I guess I will keep on using my command line when using the linux boxes :).
(3,331 Views)
You are right !!!
(3,327 Views)
