Source control using microsoft TFS
 I am trying to set up the source control in labview to use Microsoft TFS. I have TFS installed on my machine but when I try to set up the source control I only get the choice of NONE on the pull down box for the source control selection. The help file said that it should self populate by reading the registry to determine what type of source control is being used.
Any Suggestions would be appreciated
Jim
(4,009 Views)
Accepted by topic author Jim_Glanz
To connect with TFS an additional plugin is required. There seem to be at least two versions of the plugin - 2008 and 2010. Here are the links:
2010
2008
Once the plugin is installed, an entry for TFS should show up in LabVIEW.
George M
(4,002 Views)
