Source safe add
I am trying to add a vi into source safe inside LabVIEW through MSSCCI.  When I try to add a file to source safe,  the software would also prompt me to add a bunch of dependant vis that are not related (they shouldn't be dependant).  Why is that?
Kudos and Accepted as Solution are welcome!
(2,581 Views)
Well they are related to the VI (otherwise they won't be listed).
You can set if callers or callees should be included in these dialogs.
However it's a good idea to find out how these VIs are related (are they in the same class/library)
Use the hierarchy window to explore the links.
Ton
My LabVIEW Ideas
(2,577 Views)
