Source safe function
Hi all,
I am going to start using TFS as my source safe application inside labview.  Is there some cool tips that you can share or something critical that I need to watch out for?  Thx!
Yik
Kudos and Accepted as Solution are welcome!
(5,099 Views)
Really? You're using The Fashion Spot? (It was the first hit on a Google search for "TFS") Does this mean you have to change it every season?
(5,065 Views)
Accepted by topic author jyang72211
Yik,
       I assume you mean that you are using Microsoft Team Foundation Server as your Source Code Control (I like The Fashion Spot better though). This is not on the list of officially tested and supported SCC providers (http://digital.ni.com/public.nsf/websearch/26EC5904169430CE8625706E00743997?OpenDocument ) but you can still try to use it yourself. This document (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000g0y5SAA&l=en-US) can help you add TFS to the SCC list in LabVIEW. Other than that there really aren't any good documents involving LabVIEW and TFS so if you run into any issues and find a solution, post them on the forum so that other customers might benefit from the knowledge as well. Good luck!
(5,033 Views)
Yeah, it is the fashion spot, 🙂
Yik
(5,010 Views)
