Source works but exe crash due to memory allocation problems
My problem is that. I have an application on a crio 9073 and when I work with the source I haven't problem. When I build the application and I run it I can see on NI distributed system manager that the memory decrease continuosly until the Crio crash.
When I check on NIDSM with the source running I haven't problems...
Inside the application I've no array or charts, or shift registers that grow continuosly....
(2,688 Views)
What is your lv version?
(2,655 Views)
Hi Fabio,
what does the application do? Can you post it?
How do you run it on cRIO?
D. Beninato
(2,647 Views)
