Sourece Files are not showing while creating Package
Hello every one
please help me to solve the problem. while creating package I am unable to find source files under My Computer. please see the image attached.
Thank you.
(4,104 Views)
The only source file you have in your project is a single .vi called LED.vi. You can not add .vi's to packages using the LabVIEW Package Builder. If you are trying to add other files to the package, they first need to be added to the LabVIEW Project.
On the other hand, if you are trying to make a package of vi's you can use NI's tool 'NI Package Builder'. That allows you to put any kind of source file into a package. You can download it here: https://www.ni.com/en-us/support/downloads/software-products/download.ni-package-builder.html#332606
(2,913 Views)
If you create a library inside your project and place the VI under it, you can create a source distribution.
Bill
CLD
(Mid-Level minion.)
(2,900 Views)
