Space Navigator on Labview
Hi all,
Does any one know how to acquire Signal from 3DConnection SpaceNavigator?
I'd like to know the attitude of the joystick.
thanks
Message 1 of 9
(8,685 Views)
I'm not sure since I've never used one of these before but a quick check of the website makes me think your going to need to start by looking at the SDK from the website.  Most likely the information you seek will be available via the dll calls.
Jason Willis
LabVIEW CLD
Wire Warrior
Behold the power of LabVIEW as my army of Roomba minions streaks across the floor!
Message 2 of 9
(8,665 Views)
Ive had luck using the active X VIs to get data from it. Check the devkit on the 3Dconnexion site, it has the definitions of all the commands.
Message 3 of 9
(8,378 Views)
Hi Neil84,
You can monitor your "3DConnection SpaceNavigartor" with the "Input Device Control palette".
I invite you to read the following information on our website about this topic
How Can I Monitor a Joystick, Keyboard, or Mouse in LabVIEW?
http://digital.ni.com/public.nsf/allkb/CA411647F224787B86256DD000669EFE
Best Regards,
Message 4 of 9
(8,343 Views)
Neil84,
The "Input Device Control" VIs in LabVIEW did not work for me. They do not detect the 3DConnexions device not can they read data from it.
Has anyone gotten this to work in LabVIEW?
Thx
Message 5 of 9
(7,821 Views)
Works great for me,
all I did was plug in the SpaceNavigator, using the drivers windows found itself and I could get data from it using the "Initialize Joystick" and "Acquire Input Data" VI's
Message 6 of 9
(7,658 Views)
I am having the same trouble, LV can't detetct the joystic/Space Navigator
I am inputing the device id to be 0 (default) as there is only 1 joystick installed, all I get is  -1 for the buttons and none for axes.
Do I need to install the proper driver using the NI VISA Wizard or am I missing anything, any help will be appreciated.
FYI, using LV 2014
Message 7 of 9
(7,411 Views)
I realized that as soon as you install the 3Dconnexion driver (3Dconnexion home) for the Space Navigator, LabVIEW can no longer read data from the Space Navigator. After I uninstall the driver, LabVIEW again reads the data fine. (A restart is required after uninstalling the Space Navigator driver.)
Message 8 of 9
(6,414 Views)
I can only see it as an emulated joystick (KMJ Emulator) in LabVIEW 32-bit.  In LabVIEW 64-bit I see a bunch of other devices listed as joysticks (including my USB keyboard), but no KMJ Emulator.
(I'm using Win 10 64-bit)
Message 9 of 9
(6,327 Views)
