Spartan-3E ACD/DAC Driver Labview FPGA
Hi Miguel,
Could you clarify your question? As Vince mentioned (great research Vince!) and as chefweb implemented, designing a PCB connector for the external FX connector to access ADC and DAC is the way to go.
With warm regards,
David D.
Message 11 of 19
(2,807 Views)
hello I am an academic user (student)
I am working with spartan3e and labview2009-mofulefpga. I am designing an impedance meter to measure cables that working with frequencies between 1-2 MHZ.
         I need to generate a signal with dds method . That signal is taken out of DAC (A,B,C,or D) and introduced in a block (PCB),
         I saw an example (to begin) in this website:
                                     http://zone.ni.com/devzone/cda/epd/p/id/6066
         but I can' t to do run the files (for example FPGA DDS Generation Sine 1-ch ), because that examples are designed to  targets NI RIO , and labview 8.5.1
My questions is: How I can set the parameters to run the files on spartan 3e??  How could I get the signal generated? Is there some information about dds on spartan 3e with labview 2009?
please advise
Message 12 of 19
(2,597 Views)
please advise
Message 13 of 19
(2,589 Views)
hello vincet claes ,  I am an academic user (student)    , I can not find what I'm looking for, yet
         but I can' t to do run the files (for example FPGA DDS Generation Sine 1-ch ), because that examples are designed to  targets NI RIO , and labview 8.5.1, I also saw the examples in(${LVDIR}/Examples/Spartan-3E/Converters/), but I do not know how to integrate both files
My questions is: How I can set the parameters to run the files on spartan 3e?? Is there some information about dds on spartan 3e with labview 2009, or  Is there a course that includes the item direct digital synthesis (DDS on Spartan3 with labview 2009? or pay for a consultation on this issue? in National Insturments?
kind regards
pablo martín  (charlysed)
Message 14 of 19
(2,574 Views)
kind regards
Message 15 of 19
(2,569 Views)
Hi Pablo,
I'm not sure about the compatibility of those specific examples, but I do know that FPGA examples can be moved onto other targets explained here: Moving Examples to Another FPGA Target.  Since the Spartan-3E appears in the project window in a similar fashion as an R-Series FPGA board, then FPGA examples originally targeted to NI-RIO may be able to be retargeted in a similar fashion.  I hope this helps!
- Greg J
Message 16 of 19
(2,541 Views)
VT-Hokie thanks, now I'm trying to integrate the two examples and also considering what you said
Message 17 of 19
(2,530 Views)
Pablo:
I believe there is a series of tutorials on the NI Developer Zone for working with Spartan 3E targets. Below is the link to the material:
http://zone.ni.com/devzone/cda/tut/p/id/6848
Good luck!
Caleb Harris
National Instruments | http://www.ni.com/support
Message 18 of 19
(2,504 Views)
Message 19 of 19
(2,493 Views)
