Spartan-3E Starter Board Emulation Mode
Does anyone know if the Spartan-3E Starter Board supports emulation mode in LabVIEW FPGA?
If so, how do you enable it?
(2,633 Views)
If the board supports emulation, you can enable it in the properties window for the FPGA target in the debugging section.  If the board doesn't support it, you won't have that option.
Jeremy_B
(2,604 Views)
