Spartan-3E, StrataFlash Memory - wrong reading!
Dear Friends,
I have done an example for using the Spartan-3E kit StrataFlash Memory.
I got a problem I couldn't figure-out how to fix!
The problem is:
1-  writing the following values to the StrataFlash:
1              2              3              4              5              6              7              8
2- Reading the written values from the same address, I get:
1              3              3              5              5              7              7              9
Also the reserved space on the FPGA is huge, I believe that this design can be optimized so that we can save some LUTs.
I wonder if someone can help and check my design, then advise the optimization points!
Also, I tried to read the identifier code, but I got the value 88h and I didn't understand this value!
P.S. Labview8.6.
(3,865 Views)
Hello guys,
 I'm still looking to getting a response!
(3,798 Views)
I've never programmed he strataflash before on this board, but here are some resources I use for the Spartan:
http://pwo.fpga.be/coursematerial.html
LabVIEW FPGA Module Training for Xilinx Spartan 3E XUP Hardware
Not sure if the strataflash use is in there, however. Since these are academic only products, I dont think classes get that in depth on the boards.
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(3,790 Views)
Thanks for your feedback but it seems theanswer has no relationship with the question, isn't? The below resources don't includeprogramming Strataflash!
The LABVIEW-FPGA Driver for Spartan-3E starterkit provides an example, but even this example is giving a wrong reading ormaybe writing in the first place! So, you may would ask the guy who wrote thedriver example about this problem. I don't think the problem is in the written example,it seems to me the problem has to be in the Strataflash settings/modes!
If you have done any example about programming Strataflashwith RIO or any other module, please do me a favor and attach.
Thanks & Looking forward to getting yourfeedback and test the attached example!
(3,780 Views)
