Specific data arrangement in the saved file
What are you doing with Excel? Did you give the file an .xls extension? That does not make it an Excel file. It's still a text file with an incorrect extension.
Message 31 of 36
(729 Views)
No i creatw a new file in excel, then save it as an excel file itself. Then i put it into the file path in my vi. I didn't just extend my text file's name.
Message 32 of 36
(723 Views)
Same thing. Saving it as an Excel file requires a specific format. Evidently your's does not match. Save it as .txt and use Excel to Import it.
Message 33 of 36
(716 Views)
Hello I tried to change the beginning header by using controls instead so that the user can choose the unit of each value, but the error about the format came out like in the attached file. And how can I link these control units to the data mainstream. The user only adjusts the unit from these controls, then it will correspond in the main stream.
Message 34 of 36
(687 Views)
After I have tried to rearrange my code to save the files, it looks good. The file has everything I expected, except one thing; there is an extra "NaN" in my file. even though the number of NaN in the array is equal to the data inputs.  You can see in my text file.
Message 35 of 36
(664 Views)
2 more sub vi
Message 36 of 36
(663 Views)
