Specified UDP Datagram
Hello!
I was reading on UDP communication and noticed how it says that with all the bits in a byte set one then routers "send to all" IP addresses in that range.
I'd like only a very specific IP address and even though I specified that address in read and write it still takes in a range.
I have one IP address that is taking up a lot of the data so sometimes the UDP port doesn't get the data I need. Does anyone know how to change this range?
Message 1 of 1
(1,445 Views)
