Specifying a Top-level VI to build a PDA application
Thinking positive: it's good to have LARGE labels on a tiny PDA screen Smiley Wink. Many endusers would be grateful for this!
Paolo
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 11 of 14
(882 Views)
5 stars to pincpanter for hitting that one on the head ...
Greycat
Message 12 of 14
(873 Views)
Is it possible in Labview the disable a Control is the statement or condition is false at runtime? For example, if field are empty, then disable the 'next button'
Message 13 of 14
(861 Views)
Yes you can do that ... first you would have to evaluate your condition ... and depending on the outcome you would want to use the Property Node for Disabling or enabling the control in Labview.  Alternatively you could use the Visible Property through the property node to do the make the control disappear completely.  In Labview PDA(which does not support Property nodes), you would have to use the "Show or Hide Control" vi found in the Application Control palette under the functions palette to accomplish this..
Greycat
Message 14 of 14
(844 Views)
