Spectral Measurement Express VI
I want to process several signals using the Spectral Measurement Express VI.  Does this VI work on multiple signals?  I looked at the block diagram and it appears to be working on only one signal.
Thanks.
--Robert
(2,851 Views)
Hi Robert,
i think you can also connect an array of signals. Did you try it?
Mike
(2,835 Views)
I had an array of signals wired to it, but I do not have the actual hardware so I am not sure if it was working.  The data (written to a file for the various signals in the processed array) appeared to be different, but I wasnt sure if that meant that it was correct.
--Robert
(2,831 Views)
