Spectral Measurements - Y axis units?
All; When I choose to use the RMS magnitude selection on the spectral measurements dialog attached below.... If I am taking angular velocity measurements in degrees/second, what are the units of magnitude on the y axis of the subsequent frequency domain result? Additionally, what are the units if I select any of the other selections? Thanks!! -Nick-
(2,853 Views)
When the selection is rms the output units are the same as the input units. Power Spectrum units are the square of the input units and power spectral density is in units of (input units)^2/Hz. This information is in the detailed help for the VI.
Lynn
(2,830 Views)
