Spectrometer's drivers that stopped working in Labview 8.5
I have some drivers provided from NI that operate and control a series of spectrometers manufactured by Ocean Optics.Although these drivers were working fine for Labview 7.0 and 8.5,all of a sudden when I try to open the VI's now on 8.5 I get the message
Labview:VI version is too early to convert to the current Labview version.
An error occurred loading VI
Labview load error code 10:VI version (4.0.2) is too old to convert to the current Labview version (8.5)
The strangest thing is that these VI's worked for both versions before and I can't figure out what's happening.
Could you give me some advice or help?
Here are a couple of them
(3,332 Views)
duplicate post.
You asked the same question a week ago and were given an answer. Please look at the answer and if you have questions, respond to the original thread. If you had a copy of the drivers that were once working in 8.5, they must have been a set that was converted to your previous 7.0 version of LabVIEW. By the way, those drivers are not provided by NI. On the Instrument Driver Network, there is just a link to the Ocean Optics web page.
(3,328 Views)
I tried the two LLB's you posted. They worked in LabView 8.2 but did not
work in LabView 8.5.
I think your only option is to stay in LabView 8.2 or else upgrade to
Ocean Optic's newer OmniDriver product, which will work in LabView 8.5
Message posted using http://www.talkaboutprogramming.com/group/comp.lang.labview/
More information at http://www.talkaboutprogramming.com/faq.html
(3,277 Views)
Some one used the OmniDriverSPAM32.dll in matlab, i can't make to work,
(3,228 Views)
