Spectrum Analyzer (Keysight PXA) get Trace using binary format
  1. The drivers uses ASCII format. I need binary format. Many points and many traces.
  2. Several posts touch upon this subject but don't give a good answer.
  3. I've attaced my code.
  4. Visa read binary block data. vi was lifted from another post but I can't find it to give credit.
  5. Byte array to trace.vi has default data that was taken from my PXA spectrum analyzer. I stole the basic idea but made it much more pretty. It needs to convert 8 bytes to a double but it doesn't.
  6. Because I am using Windows I am using ":FORM:TRAC:DATA %s;:FORM:BORD SWAP;" where %s is real,64 to get the binary data. Don't know if SWAP is required.
  7. I have a general idea how this works but the details escape me. MSB, LSB swapped and normal. My eyes are glazing over.
Thanks for any good help.
Norm
(5,494 Views)
Hi Norm,
What sort of problem are you running into in your code? Are you receiving an error, or unexpected data somewhere?
Tom D.
Staff Software Engineer
NI
(5,452 Views)
Accepted by topic author Viper
Try this. It works well for me.
(5,445 Views)
You can save a little processing time if you delete the "String to Byte Array" from the SubVI and the correstponding "Byte Array to String" in the main VI. Just leave the binary block as a string, then Typecast to SGL, then convert to DLB.
(5,441 Views)
Thanks for your help, It's working great and it did save some time. I have reposted here in a single vi with conversion to a trace [(x,y)].
Thanks jamiva!
Norm
(5,424 Views)
