Spectrum Analyzer USB-SA44B - Peak, frequency & amplitude measurements of RF the signal
Hello
I'm using the Signal Hound USB-SA44B for RF quality measurements of our products.
I need to get basic main measurements like
  1. Find the Peak
  2. find Main frequency (per found peak)
  3. measure Main frequency & amplitude
For instance get measured in the found peak point is: frequency 433.92 MHz and amplitude -21dBm?
Unfortunately manufacturer didn't provide simple examples for measurements.
My development environment:
  • LabVIEW 2013
Attached the output graph that I receive during the test
Thanks in advance
(3,602 Views)
Seems like this whitepaper on peak detection might be a good start:
http://www.ni.com/white-paper/3770/en/
(3,553 Views)
Thank you for reply. Unfortunately your response  was in the spam folder of my mail, and I just today discovered it. I'll try to build provided algorithms, but I expected some working .vi, that was verified  . I tried several peak detection functions and configurations. they recognized the peak, but not automatically showed the time indicator. So I have to build it by my self .
(3,515 Views)
There are also some example VI's bundled with LabVIEW that might do some or all of what you need.
Searching the NI Example Finder within LabVIEW for 'peak' shows a whole bunch of examples that deal with detection and analysis of peaks.
(3,507 Views)
thanks, I'll check
(3,501 Views)
