Hi Ben,
Thanks for your quick response.
I am already using this NO_DELAY trick and getting about 10Mbyte/sec between two machines (while writing the stream to disk at the same time).
But now I have two more machines that need to receive the same stream, so I am considering IP multicast, which is based on UDP. Unfortunately the reference you kindly gave me only mentions TCP.
I was just wondering what kinds of speeds people have been able to achieve using UDP multicasting, and whether they have resorted to either custom UDP VIs and /or fancier ethernet controllers.
Thanks!
Cas
