Speed of program
My program is slow,
My programm communicates with a network analyzer, and also with excel. (after a buttonclick) But are there some general rules to speeding things up, because my application is very slow.....
Do you have got any tips?
(2,862 Views)
On your front panel select Tools>Profile>Performance and Memory.
This tool shows you where you might be able to improve performance.
Also,  for a lot of the canned instrument drivers I end up modifying them because some are pretty slow.  Make sure you are not calling unnecessary routines every time you need to take a measurement.  A lot of the drivers call setup and init routines along with your measurement routines every time you call the instr driver.
And if you are calling excel a lot that can be slow.  I usually dump data to excel at the very end.  While my programs are running, I create a text file for raw data.
Brian
Brian
(2,827 Views)
