Speedy-33 Echo Example with DSP Module's Variable Delay Block
I was trying to implement the echo effect using the DSP Module's Variable Delay Block, it works fine and I could hear the echo nicely, however, it was restrictred to the maximum delay of 4095 (for frame size of 1, and 4094 for FZ of 2, etc....). This means that the maximum delay I could get is 0.5 second with 8k sampling. May I know what is the reason behind? is it due to the HW buffer or what? and how to workaroud this?
CL
Message 1 of 1
(3,010 Views)
