Splinetable mint controller
Hi!..
I'm using Spinetable for Baldor motor's control, Do you know how to make a variant data to run this block?, because when I run my VI, it shows me the -2147024809 error, .. someone can help me? please!
Greetings
(3,962 Views)
Hello KinTro2,
Can you post the VI or maybe an screenshot of it? How are you trying to control the Baldor motor? Have you searched through the website with that error code?
Eric NI
(3,924 Views)
Sure!, I'm trying all kind of data as possible but it shows me that error, this is my diagram for Baldor motion, Next Move e100.
I researched that error but it says: "Invalid parameter"..
thanks a lot.
Greetings
(3,920 Views)
(3,919 Views)
Hello KinTro2,
I have researched about this issue and found that some other customers solved the issue by adding a node that closes all the modules before executing the program, however I do not have that much experience with the Mint Controller so I do not know if that would be valid for your case.
Eric NI
(3,887 Views)
Hi Eric!
Thanks for the advice, I'll work with that situation and I hope to solve the problem.
Greetings
José
(3,879 Views)
