Split 10 bit words into two parts
Hi all
I have 10 bits word and I want to split the word into two parts .The first  part is  bits (0-7) and the second bits(8-10).
Sattam
(2,856 Views)
No, you have a DBL array , ending up with U16. A simple scaling to the 10bit integer range is all you need before converting to U16. Get rid of your FOR loop completely.
(2,847 Views)
Accepted by topic author Sattam
Of course your "bits" need to be arrays, not scalars. Once you make them arrays (right-click...change to array), they can be extracted and displayed as follows.
(2,839 Views)
(2,774 Views)
