Split - Zip files under Labview 5.11
Do somebod know if it is possible (with the smallest cost possible) to
compress and split a "big file" (about 6 Mb) on flopies ?? (to make
automaticaly a save of data)
Frédéric Durand
(nicer@gmx.fr_remove)
PS: sorry for my bad english 🙂
(3,211 Views)
Hello Frederic,
once I had found a VI for de/compression via zlib, but
right now I dont have it on my harddisk. Do a search
for this... The result of these compression VI (pro-
bably an U8-array) you can split into smaller arrays
of the size you need (perhaps 1440000 bytes for a 3.5
HD floppy?) and save to different files. Easy and no
cost...
Gerd Wieczorek
(3,211 Views)
Jim Kring's OpenG has this functionality available. I cut the following from his bio.
Visit http://www.openg.org for more info.
I believe they use WinZip but I am not sure.
Ben
(3,211 Views)
