Split string to array
Hi
I needs to split at string to array
I use this code but the decimals is gone.
Message 1 of 10
(13,126 Views)
That would be because you are formatting it a an array of decimal integers (%d)  Try "%f" to format them as floating point numbersSmiley Wink
Message 2 of 10
(13,121 Views)
Thanks but the result is the same 😞
Message 3 of 10
(13,106 Views)
Message 4 of 10
(13,100 Views)
Not sure how but, do show the display style of the string constants and this is what I get.
Message 5 of 10
(13,089 Views)
Hi Michael,
maybe your computer is set to use a comma as decimal separator…
Try a format string of "%.;%f"! (Read the LabVIEW help for format strings!)
Message 6 of 10
(13,088 Views)
Works for me if you use the same delimiter in both your string and the spreadsheet to array vi
Right click on your string and select "\" codes display
=== Engineer Ambiguously ===
Message 7 of 10
(13,083 Views)
After changing my computer settlings from "," to "." and using this code I get the decimal but with comma ??
That's strange when I set the computer to "."
Message 8 of 10
(13,078 Views)
Hi Michael,
you need to restart LabVIEW before changes in your regional settings are applied…
Message 9 of 10
(13,072 Views)
Restart helped  🙂
Message 10 of 10
(13,066 Views)
