Split the information within each element of an array in LabVIEW
Hello Everybody
I need to resolve some code in Labview.
I have a spreadsheet with many (100,000) lines, and in each line i have this kind of info:
0.00004     0.576
0.00003     0.876,
0.00005     0.896,...
etc.
I can split the spreadsheet in lines as a first step and this is ok.
The next step is to split the information within each line in 2 arrays.
For ex:
Array 1           Array 2
0.00004          0.576
0.00003          0.876,
0.00005           0.896
Please see in attach the vi.
Can someone help me?
Cheers
Message 1 of 15
(4,812 Views)
Use Index Array.  Drag the bottom border downwards to get two outputs.  You'll want to wire a zero constant into the Column index of the upper one so that you'll get column 0 in the first output, and column 1 in the 2nd output.
Array manipulation is a basic LabVIEW skill you need to learn early on.
I would recommend you learn more about LabVIEW from here. How to Learn LV
Message 2 of 15
(4,781 Views)
First replace all "\n\s+" with "\n", and all "\s+" with "\s" (use Search and Replace String twice, set it to regular expression). That would simplify using Spreadsheet String To Array. You'll now have a spreadsheet string with "\s" between columns and "\n" between rows. Just as Spreadsheet String To Array likes to have it.
You might remove the comma's with the first replace. So don't replace "\n\s+" with "\n", but replace ",?\n\s+" with "\n".
Spreadsheet String To Array should have a 2D input. Then the separator should be a \s. The second dimension uses \n as separator by default (and can't be changed).
Then use Index Array to get the desired row or column.
Message 3 of 15
(4,755 Views)
Hello Revans
Thank you for your reply.
In the way you are proposing me, I get only elements of array. I can't proceed manually for 100,000 elements.
Once again. My array is :
000000  123000
002000  124000
003000  125,000
100000  200000
What I need to do, is to get from the main array 2 subarrays as follow:
Array 1
000000
002000
003000
100000
then
Array 2
123000
124000
125,000
200000
Can someone help me to solve this thing
Message 4 of 15
(4,754 Views)
Hello
I haven't got results.
Please can you make it the code.
All I need to do is:
Hello Revans
000000  123000
002000  124000
003000  125,000
100000  200000
Array 1
000000
002000
003000
100000
then
Array 2
123000
124000
125,000
200000
Can you help me on this issue.
Best Regards
Message 5 of 15
(4,747 Views)
Labview
Hello
My array is :
000000  123000
002000  124000
003000  125,000
100000  200000
Array 1
000000
002000
003000
100000
then
Array 2
123000
124000
125,000
200000
Best Regards
Message 6 of 15
(4,743 Views)
Where do you get stuck?
Post your new attempts.
If we start making code for everyone, this forum would soon change from Q&A to Do This Do That. It would also cost me\us too much time. This is basic stuff, I think we do you a favor when we let you try this yourself. Teach you to fish, not hand over the fish, if you will.
Message 7 of 15
(4,734 Views)
Hello
I have tried several time but I don't have results.
Can you help me please.
Cheers
Message 8 of 15
(4,731 Views)
Step 1:
Use Search And Replace String (ctrl+space, enter Search and Replace).
Right click it, select regular expression.
Wire the input, and the reg.ex. and the replacement string.
Post your findings, let us know where you fail.
Step 2:
Do this twice.
Step 3:
Wire the result to Spreadsheet String To Array.
Change the Delimiter to \s.
Wire a 2D string array to it, that's what you want.
Step 4:
Use the resulting 2D array and Index Array to get the result.
It should look like this:
Message 9 of 15
(4,725 Views)
Slight improvement (spaces at the beginning gave error):
Less code, more complex reg.ex.
Message 10 of 15
(4,719 Views)
