Split the screen
(3,719 Views)
Hi Learner,
you still don't seem to know how to type text here as message. Instead you simply embed a big picture...
To your question:
Ever thought about drawing two rectangles side by side? With different colors/graylevels?
As can be seen in your big picture there are 4 coordinate inputs to the DrawRect function...
(3,718 Views)
Hi GerdW,
So sorry I am so used to it. I am trying to obtain a rectange with the two colors inside.
(3,715 Views)
Hi Learners,
no, you should draw two rectangles using different colors - not just one!
(3,707 Views)
Hi Gerdw,
You mean using the same code? but different colors?
(3,705 Views)
Hi Learner,
is it so hard to believe? Your first message shows a white rectangle next to a dark rectangle.
So: two rectangles in two different colors...
Come on, just try it:
(3,701 Views)
