Splitting Strings by Character Number
I'm trying to find a way to differentiate duplicates of files based off of their revision. Two files are the same but of different revision if they have the same file name, but a different suffix (always a capital letter) at the end.
For instance:
ABC123A.xxx
ABC123B.xxx
are both of the same file but of a different revision.
ABC122A.xxx
ABC123B.xxx
are of different files and different revisions.
My problem is that I need to be able to determine if two files are the same but of different revisions. My idea for a solution was to strip the file extension, then split the remaining string into two, one being n-1 characters long, and the other being 1 character long. Is there a way to do this? All split string methods I've seen so far either require a complete match or a delimiter.
Thanks!
(6,627 Views)
Accepted by topic author reesl
Use "String Subset"
(6,611 Views)
To add to Prettypwnies anser:
/Y
Qestit Systems
Certified-LabVIEW-Developer
(6,581 Views)
Search and Replace string to find the location of your period (start of your file extension), decremented to get the rev digit, and fed into string subset of length 1 to pull out the character of interest.
(6,577 Views)
If the string format is really that easy (and stays that easy) use Scan From String.
Use format specifier "%[A-Z]%d%[A-Z]" (characters in string, number, characters in string), and you'll get the string and number as output (extract to get 3 outputs). Optionally, use "%[A-Z]%d%[A-Z].%s" to also get the extension.
Once you have the results, you can either use a set (new in LV2019), variant attributes or an array to spot duplicates. Not sure if that's the showstopper, but we can help once you're there.
(6,557 Views)
