Splitting a 2-Dimensional array
I've got a two-dimensional array with data stored in each column.
Is it possible to get each column of the array separately?
It would be like splitting the 2-dimensional array into
one-dimensional arrays, so that I can evaluate each column of the
two-dimensional array separatel? For example:
2-dimensional array would look like this:
2 5 6 9
3 6 8 10
4 7 8 9
and the corresponding four 1-D arrays would then look like:
Array 1:
2
3
4
Array2:
5
6
7
Array3:
6
8
8
Array4:
9
10
9
Thanks!
(3,231 Views)
Use the index array function. As you wire it to your array, it will reshape automatically with two index inputs, the second being 'Disabled index (col)'. If you wire a constant to the second index, you can extract from the array the desired colums (since it is a zero-based index, wire 0 to extract the first column, your 2-3-4 array, 1 for the second and so on).
Roberto
(3,231 Views)
Hi marc,
find attached VI ... I'm splitting your array in two different ways - one is for separate column computing (index array) and the other for 'loop' related operations.
Hope this helps.
(3,231 Views)
