Splitting a 32 bit integer into two unsigned 8 bit integers
This is my first project and post so please be gentle.
I have a Build Array that currently has seven unsigned 8 bit integer inputs.
A lot code currently is input to Array Size as a 1D Array String and comes out as a 32 bit integer.  I would like to split this somehow into two separate 8 bit integers to feed into the Build Array, which will consist of the first and second part of the data.  The Build Array will then have eight unsigned 8 bit integer inputs instead of seven due to the output of the Array Size being split into two parts.
Any ideas?  Thanks.
(6,490 Views)
First you will have to coerce the I32 into an I16 because an I32 would consist of 4 bytes.  This will effectively limit your range from -2147483648 to +2147483647, to -32768 to +32767.  But that probably won't be a problem.  Look on Numeric palette, Conversion for that function.
Then look on Numeric palette, Data Manipulation for the split number function to take the I16 into 2 I8's.  then you can coerce to 2 U8's.
You can probably do this more simply as coerce I32 to U16, then split to 2 U8's.  But I'll leave that for you to experiment with.
(6,479 Views)
Worked perfectly!
(6,441 Views)
