Splitting a string based on delimiters
I am coding an application that captures an input string from a GPS device via the serial port.  I'm able to get the string just fine using VISA, my problem is with parsing through the string once I get it in memory.  Looking through the string pallet, I didn't see any functions available to split the string into each of it's components.  As an example, this is a NMEA sentence I pulled from the GPS device:
$GPVTG,0.0,T,0.2,M,17.4,N,32.2,K*4D
where:
$GPVTG,        The message for Track Made Good and Ground Speed
0.0,                 Course (in degrees)
T,                    Indicates True course
0.2,                 Magnetic course (in degrees)
M,                   Indicates Magnetic course
17.4,               Ground Speed
N,                   N = Knots
32.2,              Ground Speed
K                    K = Kilometers Per Hour
*                     checksum tag
4D                  sentence checksum
Currently, I can pull this string by using the "Match Pattern" string function - when I get the $GPVTG message, I get the remainder of the string.  After that, I pass the remainder of the string to the "Scan String For Tokens" function.  The problem here is that I have to index through the string based on where the comma's are located - and they are not always in the same spot.  For example, if I wanted to get "Ground Speed" in Knots, based on the string above I would begin indexing at location 12 (assuming that index 0 begins at the very first comma).  This would work - however Course will not always be 0.0 - it could be 256.0 which then changes the index location of what I think is the beginning of Speed in Knots.
Here's my question - is there a function in LabVIEW that splits a string into an array of strings based on delimiters (such as a comma)?  I've used such a function in C# .NET - and it works great for what I want to do, but the string functions pallet doesn't have anything like this.  If there is no such thing as a split string into an array of strings - how could I go about making one?
I'm using LabVIEW 7.1 Developer Suite on a Windows XP box.
Thanks in advance for any help!
(3,956 Views)
Hi Max
This is how I would do it.
Hope it helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,949 Views)
Here's a way of doing it.
Edit:  Oops, looks like I was beaten to it!
Message Edited by Novatron on 09-02-2005 09:47 AM
(3,948 Views)
Or just use the Spreadsheet String to Array.
(3,940 Views)
Thanks ya'll - good feedback on a relatively simple problem.  I got your idea to work Thomas - and it's pretty easy.  Now all I have to do is get the serial port to work the way I need it to - it drops some of the NMEA messages once in a while.  Add that to polling for data on a USB-6008, and things start to get out of whack.  Thanks again!
tsc
(3,924 Views)
