Splitting a string up into an array...
Hello all, I've just started to use LabVIEW as part of my University
project. I have looked all over the place for the information that I
seek but as yet to no avail.
What I wish to do is split a string up into an array and then find out
how many items are in that array.
Say my string is "FOO,BAR"
I have tried to use the 'Scan Strings For Tokens' VI to some success.
It manages to find "FOO" with "," set as the delimiter. How can I
store this in an array and then go back and retrieve the remaining
tokens? The string contains a variable number of tokens.
I think that I could also use the 'Search/Split String' and 'Match
Pattern' VI's to produce the same effect. What is the best way of
tackling my problem?
Hope someone can help as
I've a real headache after tonight...
G.
PS- I'll push my luck and ask if anyone could possibly email me
(gibbo_97@yahoo.com) a simple VI that will do this task 🙂
(5,511 Views)
"Adrian Gibbons" wrote in message
news:d5d90f23.0212051633.2698add6@posting.google.com...
> Patte
> Hope someone can help as I've a real headache after tonight...
I don't think I understand what you want to do. If we use FOO,BAR as an
example what should be the final result(s)? Would you want an array with
FOO and BAR and a count of 2?
(5,511 Views)
use the build in function spreadsheet string to array
see attached example.
greetings from the Netherlands
(5,511 Views)
Now, you wouldn't want someone to devalue your learning
experience would you 😉
However, try this...
Use a "Spreadsheet string to array" vi. Set the delimeter to comma,
set the format string to %s, use
initialise array to create a 1d string
array(the length is immaterial so set it to 1) and connect this array
to the array type input of the "Spreadsheet string to array vi".
Voila, job done.
Remove "spamkill." when replying to this message
(5,511 Views)
