Splitting data from waveform output from niScope Multi Fetch Cluster
I am trying to split the data of a 1-D array of clusters.  I am using a PXI-5421 function generator and a PXI-5122 digitizer.  The NiScope Multifetch Cluster.vi retruns output data of the waveform as a 1-D array of cluster of 3 elements.  This array contains information from channels 0 and 1.  I am trying to extract the waveform component information from each of the channels so I can operate on them an re-assemble two waveforms.  Can someone point me in the right direction?  I can't seem to come up with the right tool from the array or cluster tools.  Thanks.
Jeff
(3,625 Views)
Accepted by topic author jtd30
You just use an Index Array and an Unbundle by Name or Unbundle.
Message Edited by Dennis Knutson on 04-30-2009 10:41 PM
(3,611 Views)
I worked perfectly.  Thanks.
(3,586 Views)
