Spreadsheet String To Array DBL Performance Improvement
While developing and profiling a batch data-analysis program, I found that the "Read From Spreadsheet File.vi" function was where the majority ofthe execution time was spent.  Digging further, I found the time was spent in the "Spreadsheet String To Array" function.  Obviously I cannot look inside this function, but I wondered if I can somehow speed it up.  Attached is a Vi that illustrates what I came up with as an alternative.
Basically using "Spreadsheet String To Array" only to split it up to a 2D String Array, and then "Fract/Exp String to Number" to convert the strings to numbers.
It consistently runs in just over 60% of the time of using Spreadsheet String To Array on it's own to do the conversion.
I am curious as to why using the two functions is quicker than just the one on it's own? Perhaps NI can improve the internals a bit?  Or perhaps it is not a fair comparison?
Labview 8.6f1 Win XP SP2
Message Edited by pauldavey on 03-25-2009 02:55 PM
(4,992 Views)
Nice post paul Smiley Wink
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(4,981 Views)
Thank you for bringing this to our attention! I will be putting forward this question to our R&D department. If I do find any useful information, I will go ahead and post it here.
Vivek Nath
Machine Vision
(4,925 Views)
FYI:  This behavior is still there in LabVIEW 2010.
(4,237 Views)
Adding a couple of other conversions to test against i noticed that:
1. Scan from string through a double loop was the slowest
2. Scan Value was slightly faster
3. Direct conversion through Spreadsheet to array as in OP
4. 2-step convert through Fract/Exp.
Could it be that Spreadsheet to array uses Scan Value internally?
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,215 Views)
Hello Yamaeda,
Would you be willing to post your code here?  I would like to take a closer look and inform our R&D department if necessary.
Lynn
Senior Systems Engineer
(4,177 Views)
