Spreadsheet String To Array Function Tab Delimiter
Hi all, I'm trying to use spreadsheet string to array function to read in multiple lines of texts and separate them into a 2D array. I have trouble using the delimiter. The default delimiter is tab, if I leave it unwired or use the Tab Constant, it works, but if I use \t, it doesn't work. I'm using Labview 2013 and Windows 7 64bit.
Anyone knows what's going on? Also, if I want to use multiple delimiters, what should I do?
Thanks!
(6,937 Views)
By default the deliminater input is set to normal display.  youll need to change it to code display to use the \ functions.
Also found this thread, might help with multiple deliminaters.
http://forums.ni.com/t5/LabVIEW/read-spreadsheet-with-ultiple-possible-delimiters/m-p/805080#M367071
-Matt
(6,924 Views)
Accepted by topic author Z.Wei
right click on your tab constant, select 'code display'...you might find a surprise:
you dont need to insert a tab manually since the function is defaulted to it already, since you have...youll find a double backspace '\\'
(6,873 Views)
